Stern to mooring -what's best protection for a classical European pontoon (see pic)
Sardinianwave
New Member
30 May 2020
This is the view from my Beneteau 28.. What's the best protection? I always sailed in the North East of England with my previous yacht so never really moored stern to before...now I have to do lot of practice as my new boat is moored in sunny Sardinia... also want to make sure boat is safe as we can have quite strong winds.
I was thinking about pontoon Fender and a flexi Fender on the column... Vs a stern Fender and a flexi Fender on bathing platform and column?
I carry a big ball fender for stern-to berthing, 24 inch or more. That has always been sufficient. At one time I used a foam fender about 36 x 15 inches. It worked but the lines pulled through the foam.
The trick is to pull the boat well off and use a passerelle to avoid collisions in ferry wash and the like. Our fender is only there for initial berthing in most cases.
One of these?
Plastimo Dock Fenders - Jimmy Green Marine
I use two ball fenders tied horizontally together with a metre gap. I always prefer to have the ideal arrangement on the boat so it can be used everywhere not just my home pontoon.
Is that a bolt-on swimming platform? I have the same. I just use 2 fenders that I tie off at the pushpit in such a way that part of the fender is above the platform. I'm afraid skippyballs will just be pushed under the platform.
BTW trick is to stop your boat well away from the pontoon, get the windward mooring line onto a cleat, then the leeward, pick up the lazyline, tension and tie off the lazyline, put the engine in reverse and tension the mooring lines. And use your passerelle. That way there is less chance that a surge will push your boat onto the pontoon (or in your case if you're really unlucky, under the pontoon). The lazylines are normally very long and have enough stretch to do this.
