BigStu
Active Member
I was after a quick bit of advice on a new boat I have purchased. I have the stern gland off the boat (Westerly Longbow) and was surprised to find that there are no ‘dogs’ to stop the torsional shear force on the rubber coupling. It his a traditional glad with two bolts to 'nip up' and tighten.
I could now look at other stern gland options- I’ve always preferred the traditional type as you can ‘nip up’ the gland if there is any leakage. However, I certainly don’t like the thought of not having ‘dogs’ on the shaft or gland which ultimately could sink the boat of the coupling fails with shear forces. However, a surveyor said to me- not a problem just use heavier duty rubber (and an engineer has suggested exhaust hose- commented that this is ideal but people don't use it as it is very expensive).
What do I do here I wonder?- go with the traditional (which I like) with a heavier duty rubber, or try a new type like a Volvo seal (but I'm not sure that will work as only about 1.5cm of stern tube is available for fixing it to and not sure you can use Volvo seals with semi flexible couplings).
Any help appreciated!
