seaangler23
Fitting a new stern gland, similar to the Volvo / radice type but it has a water feed for an internal rubber bearing, the engine is an indirectly cooled yanmar 3ym20.
Now I have 2 options for taking a feed, there’s a drain on the hose on the raw water pump outlet I could tap into for a cold water or the hose from the heat exchanger to the exhaust elbow. I know then temp after the heat exchanger should not be high enough to bother the bearing so I’m thinking there rather than bleeding off pressure before the exchanger or does it make no odds?
