seabright
Active Member
We have a traditional long keeled yacht (super sovereign 35) with a white metal stern bearing. We have sailed over to New zealand over the last two years so she has done alot of miles recently. She performed really well and gave us a very smooth ride. We took her out of the water for 3 weeks for some TLC and all went well. Once back in the water though you could hear a whine from the stern at very low revs. As soon as you increase the revs above minimum then no problem. We didn't touch engine, tranmission, stern gland of stern bearing (honest guv) so confused as to why the whine now. The whine is not harsh but more of a singing noise.
Since then, I have replaced enfine mounts and realigned the engine as part of general maintenance. We have a flexible coupling (rubbery thing) and the stern gland is in dead wood (ie not flexible). Noise better but still there. Very pleasant singing at very very low revs.
Not too worried but keen to have thoughts if possible. May replace it with a modern cutlass bearing soon. Current bearing is only 2 years old but have a hydraulic gearbox so shaft has done alot of spinning in the last 2 years. Noise only started after time ashore though and now the engine moves less and pretty aligned. Could the bearing be dry? Does it need to be, well, wet?
