sailorman
Its one of these chinese semi-flexible ebay jobs. they sell them from a warehouse in the UK. only cost a few hundred. Its made up on an aluminium plate on which the cells are laid out and covered in some form of resin (they call it tedlar). I thought it might be rubbish so I stuck it on the coachroof with CT1 so I could remove it easily. Its been coming up to 2 years service. I have walked all over it. the surface is very tough its not scratched much. no noticable degradation in output from new. I was annoyed with it at first because I sort of expected 4-5 amps but I suspect thats only ever achievable on a spacecraft in a low orbit around the sun! However, it does kick out an amp or two relentlessly. I feed it to both my domestic and starter battery banks through a maplin dual regulator. I dont keep track of amps in and out but I regularly stay on the boat for a few days with the eberspacher on and the batteries are always fully charged. I have also changed all of my cabin light bulbs for warm white LED ones and my nav lights are now LED too. Only real bad point is that the wire eminates from the panel under a siliconed-on black piece of plastic. both this and the wire itself are rubbish. I pre-empted failure and when I mounted the panel, I carefully cut the plastic off, chopped the wires down to stumps soldered some decent wire on which then goes through a deck gland and built up with epoxy putty around where the wire comes out. this has lasted well apart from dome sun yellowing of the putty.
shore power = fire hazard. possible galvanic action. and some bu*£er pinching my electric when im not at the marina.
solar panel + inverter = free, eco friendly and works wherever the boat is. Im a convert.
do you have a link pls
