Sterilising Water Tanks
Re: H2S ..... wasn\'t me that first said H2S ....
H2S is formed in anaerobic conditions when (certain) bacteria "attack" the sulphates in the water to obtain oxygen.
It is the first step in a chain of events that is now causing problems with preserved wooden ships. There is a lot of info that you can find by Googling about the Vasa which sank in Stockholm Harbour in 1628, the lagest part of a centuary later than the loss of the Mary Rose but with many similarities. It was raised in remarkable condition in 1961 and has been restored rather than merely preserved like the MR.
The good condition is attributed to low temperatures and high pollution levels but the conditions led to H2S being produced and absorbed deeply into the timbers. Subsequent decompostion of the H2S deposited elemental sulphur in the wood. Once raised oxidation of the sulphur, catalysed by iron from the rusting fastenings, has lead to the formation of large quantities of sulphuric acid within the wood which now threatens the ship. In the short term attempts are, I believe, being made to neutralise the acid already formed but reseach into a long term solution is ongoing. The latest idea that I have heard of is to chelate the iron to prevent further oxidation of sulphur occuring.
The MR is now of course suffering from the same problems.
Apologies to everyone for deviating so far off the original topic and also if it is something you already new about.
If you or any one else did not know about it then, as mentioned earlier, there is loads to find on various websites, not only about the sulphur problem but about the history of the Vasa, her sinking, her recovery and her restoration. A big difference to the amount of information about the MR, at least the amount I've been able to find!
Apologies also for any inaccuracies that may have crept into the above and for not now being able to give urls for the Vasa webites.
I have a full video of the tour of VASA ....
When as Operations Manager Baltic for BSI Inspectorate - our Baltic P&L guy was from Stockholm ... we had a Convention in Stockholm and one of the highlights was a tour of the Vasa.
Anyway .... back to H2S .... I bow to your treatise ..... but still say that if you can smell / know H2S is there in your tank / pipes etc. - it needs sorting ..... Also I maintain that it is not normal to find it as most tanks / pipework are in reasonable use to keep flushed ............
Re: I have a full video of the tour of VASA ....
I thought you might know about the Vasa. It is something I have only found out about recently though. That was as a result of being asked if I could find out anything by the old chap who owns the boat yard where I am based after I had given him a short article from Chemistry World about the measures which have now been taken to halt corrosion of the SS Great Britain.
Perhaps one or two other forumites will enjoy finding some of the stuff on line. I printed it all out to take down to the boat yard ...masses of it.
You are quite right about needing to sort things out if you can smell H2S in the water system. It can only be produced in anaerobic conditions so a system producing H2S needs a thorough clean to remove debris from the tank pipes and so on. Followed up with a serilisation with a hypochlorite solution I would think.
You mentioned that once the concentration of H2S is high enough to smell it is already above safe limits so I have looked up some figures.
Perception threshold is said to vary in the range 0.5ppt to 0.1 ppm. 0.5 parts per trillion is pretty small, someone must have had a pretty keen sense of smell or a vivid imgination although elsewhere on the same webpage (Oxford Uni) a figure of ca 0.2ppt is quoted.
Inhalation of a single breath at 1000 ppm may cause coma and the lethal concentration for a 50% kill (LC50) of humans is 800ppm (for 5mins).
There is a rapid loss of sense of smell on exposure to gas concentrations above 150 ppm.
The work place exposure limits from, EH40/2005, are long term (8hr TWA) 5ppm and short term (15 minutes) 10 ppm
The flash point is -82C the explosive limits are 4.3 to 46 % and the auto ignition temperature is 260C (I thought I would include those as they are more in your language as it were.)
Thatss not quite in agreement with what you said, I guess it smells worse than you realised. None the less if you can smell H2S something is going badly wrong. (Sorry about the pun)
I went to see the Vasa over 20 years ago when it was still being sprayed continually, and you could see a murky image of it through the viewing gallery windows (just like Mary Rose is now). 3 years ago I went again, and it's a wonderful visit ,quite magical, as it's totally restored with a museum built around it, so you can get clear views of the port side and bow, but galleries and walkways run all around the starboard and stern so you can get up close at every level
well worth a visit for anyone that loves boats
Vasa
Like you I went to see the Vasa many years ago. It would have been around the early '70s and she was being constantly sprayed with a cocktail of stuff to preserve her. I should have some photos (slides) somewhere in the house that I took at the time. I'll have to dig them out sometime.
It would be most interesting to see her again after 30-odd years.
No offence taken /forums/images/graemlins/smile.gif I surmised that because I have a seawater intake plumbed into the galley sink, with a changeover valve, that something had taken up residence in the pipe and the smell was due to decomposition.
The H2S smell wasn't very strong, but still noticeable, and the problem has now been sorted.
As Headmistress said - keep clean water going through and don't let it stand for long periods, which stops stuff breeding in the pipes.
But I would still be interested in any info on whether a filter would be affected by flushing the dilute bleaching agent through it.
Depends on the filter, Damo...some material can, some can't. However, since filters require regular cleaning and/or replacement anyway, the thing to do is remove it before recommissioning, replace with new filter or replaceable cartridge afterward.
