Sterilising water system
Is Milton suitable for Plastimo flexi tanks, and how much would I use to clean out a 100 ltr tank?
C_W
I believe Plastimo advise against the use of chlorine based cleaning solutions.
I dont know the reason.
Otherwise you could use the dose rate recommended by Milton for cleaning caravan water tanks
I would just be using it to sterilise and flush out tank then refill.
Dont use tank water for drinking, only for washing up.
Thanks.
C_W
I agree why put chemicals in.If you wash the tank out with fresh water, which contains chlorine, there shoudnt be a problem.We never drink water out the tap unless its boiled. [...] Never had a problem
Isn't that rather admitting that you do have a problem? If you were able to keep your tank clean you could drink the water from it without the hassle of having to boil it.
