shaunsm
New Member
Hi All,
Ima newbie on the forum so please be gentle!
I have recently bought an old boat (1985) and have some steering issues amongst others, Turing the wheel does not relate to the slave cylinder moving sometimes at all and then starts moving this takes a large amount of turns and effectively not usable in its current state,
I am not familiar with the hydraulics on this boat but it has a power steering pump directly connected to the engine and a reservoir and 4 hydraulic lines to the helm pump, I gather two for the power steering and two for the slave cylinder
There is a slight bit of damp on the pipes at the helm so perhaps a leak, my plan is to bleed the system this weekend and see if there's any improvement although this may be slightly challenging and I don't see how to fill the helm pump and also no bleed nipples on the slave cylinder, if the resivour is full would this suffice presumably I would still need to bleed the system somehow?
Also when moving the wheel with the engine off I don't feel any difference in resistance, I also notice the hydraulic lines get very warm, unsure if this is normal?
Thanks for any constructive feedback, thanks in advance!
Shaun.
Shaun.
