coopec
N/A
I've been working on the design of the yacht steering for some time now.
Originally I planned to use 8mm SS 7/19 cable but the experts said I should use 10 mm and pointed out the quadrant could take 10mm. The minimum diameter sheave for 10 mm cable is 7 inch (to avoid fraying) so I priced them and the Harken 178mm is $197 (plus freight). Since I needed about 10 of them that was out of the question.
I have now looked at using V belt pulleys and find I can convert the V of a A-Section pulley with minimal machining to take 10 mm cable. I will then use Bronze self lubricating bearing sleeves. (Having a Son with a lathe helps).
Can anyone see a fault with my plan?
