BarryH
The steering gear on my outdrive is set up thus. The steering cable from the helm unit passes thru a tube and connects to a drag link. The draglink connects to another lever which is pivoted in the middle. The other end of this lever is connected to another link. This link is akin to a bottle screw but on each end is a sprung clip that attatches to a ball. Not unlike a tow hitch arrangement but in minature. The other end of this link attatches to the tiller arm of the outdrive.
Got all that right. So with all these links and levers theres a fair bit of play. Looking at the cable travel for one turn of the wheel the steering cable travels the same distance as the tiller arm. So could I connect the drag link from the steering cable to the tiller arm and junk all the links. Why did Volvo set it up this way? Am I missing something dead obvious here. Why are there so many links and levers that seem to achieve nothing.
I've got three seperate points at which to "set" the steering, ie the tube is ajustable in its holder, the drag link has 4 holes it could be connected to and the bottle screw thing can be adjusted for length. With 8 dufferent points for play to appear they all add up to a bit of slop in the steering. Anyone got any views?
