Portland Billy
The wheel of my Sealine S41 is about 5 degs to port when the outdrives are amidships. Does anyone know how to adjust this ?
It aint serious but a bit of niggle !
Would seriously suggest that you merely take off the cap on the steering wheel boss. Remove the nut underneath and move wheel round a spline or two.
Unless of course it has single woodruff key, it which case you may well might just want to put up with it, cos it means adjusting the steering arm on the outdrives.
Could also suggest that 99% of boats have this irritating little niggle.
Assuming that the drives have a link bar with a connection to the steering system then you should be able to adjust it thereThanks Oldgit.
I seem to have had this niggle on most of my boats, but thought it would be nice to cure it.
I'll take the centre plug out and see what lies beneath.
My pair outdrives had either a toe in or a toe out, cannot remember which, so doing it visually by peering over back of boat might be an interesting exercise.
This might not apply to duo props. ?
A
Correct but what I am suggesting should not affect this
Would the feed back not be connected to the tie bar which remains unaffected?Just thinking out loud,if autopilot rudder feedback sensor fitted perhaps this will need adjusting as well if steering arm adjusted and what about rudder direction indicator ?
