Brent Swain
N/A
Good for you.
Steel rusts. GRP doesn't.
Get over yourself.
Plastic breaks when it hits things in the night. Steel dents a bit and stretches ,without holing and sinking.
Good for you.
Get over yourself.
I am not sure if the Captain, crew and passengers of the Titanic would agree with you.Plastic breaks when it hits things in the night. Steel dents a bit and stretches ,without holing and sinking.
Titanictastic dude.![]()
On another site, I loaded this picture in a discussion of offset hatches. I pointed out how this hatch would be under water, had it been offset.
A "World famous" designer from Washington state US ,said it would not be under water, if it had been a foot off the centreline, to leeward, and ridiculed my suggestion that it would be, as did his groupies .He designs boats with off set hatches, and charges $175 an hour for such "Expert" judgement.
He calls this type of judgement "Sound engineering,"while attacking any more logical responses from me.
One couldn't do much worse, using one's own judgement.And you say we should leave such decisions to "Experts "like him?
He has used the term "Cosmic Karma ' to describe what he relies on.
Hi Brent,
As you know I think you make many good points re steel. Though having raced boats for a lifetime I also know that top designers are unlikely to make such basic errors in their buoyancy calculations. Looking at that picture - the waves make it hard to be sure - but perhaps the designer was just factually pointing out that the hatch/companionway? appears to be still about 12' from the water?
Following this point for a moment: offshore race designs (yes plastic) must comply with strict stability requirements (AVS, STIXX, etc.), must possibly include multiple full-seal watertight bulkheads, and far-offshore races vessels must increasingly demonstrate an actual capsize recovery after a crane inverts the boat.
I fully get the importance of empirical field testing, and as stated your track record is impressive, but do you do any formal calcs re stability, downflooding angle, righting moment, etc.?
I've asked about his quality control of his steel supply, given the evidence of the Titanic that I kindly linked to for him. Still waiting an answer.I fully get the importance of empirical field testing, and as stated your track record is impressive, but do you do any formal calcs re stability, downflooding angle, righting moment, etc.?
I think you'll find the answer is no.
I offered to run a set of Brent's drawings past a friend who is a Naval Architect and well versed in these things. Brent won't supply the calculations and can't (or won't) supply the details sufficient to allow calculations to take place.
My suspicion is that Brent works on the old adage of 'if it looks right, it must be right' rather than actually calculating anything much. He then belittles designers who actually know what they are talking about in these matters and cites the fact that they disagree with him as an example of how they ought not to be taken seriously.
Folks should note that for a long time yachts and boats were designed by eye and comparison with other successful boats. Iteration was and probably still is a fundamental part of the design process. Theory and calculation came much later. The way Brent Swain designed, I think, is following a similar process, using ratios and scantlings by eye to establish a design that when built appears to work. I would not knock him for lack of theory or calculations for his designs.
Ian Nicolson's "Understanding Yacht Design" and his "Boat Data Book" are good examples of a design technique and data that rely on existing knowledge to establish a design. James Wharram is another person who's design philosophy is based on comparison and iteration, as opposed to theory and calculations.
As always there is more than one way to skin a cat, but we didn't end up with round wheels because of theory and calculation. At the end of the day Brent Swain builds boats that work. If you don't like his stubbornness and disdain for modern designers, don't debate with him about it, because as far as I can tell he will not budge one iota from his opinion.
Many years ago I bought an old Scottish fishing boat, which I subsequently converted into a substantial motor yacht. I contacted the original builders (Herd and MacKenzie, of Buckie) to see if I could obtain a set of plans. I was informed that these boats had never been built off plans, but purely by eye. These type of fishing boats were/are some of the most seaworthy boats ever. They were built entirely on the principle that "If it looks right, it is right". Just saying.![]()
I more or less completely agree. Except I’ve sailed some so called classic boats built by eye and some were wonderful I recall a 100’ plus ex Baltic Trader that had sweet lines and left almost no wake. (but sailed to windward like a dog..)
I think you can make the argument for designing by eye and iteration but there’s precious little iteration and Brent’s origami technique (ingenious though it is) severely constrains the hull shapes achievable. That’s ok to a degree but what I REALLY object to are the phantasmagorical claims about safety. If he could just be a little more balanced and pragmatic and stop making silly and proven wrong remarks about other materials and other designs then he might be taken more seriously.
His advice is actually dangerous at times and that’s why myself and other people don’t let it go.
Hi Brent,
In the early 70s, here in BC, a school teacher designed his own plastic boat and made his own sails. He had no previous boat design experience. He used all galvanized rigging, and had one sheet winch, in the middle of the cockpit; all sheets led to it.
Then he raced her,under PHRF rules , where snobs give a rating ,based on how fast the snobs think it can sail. They laughed at and ridiculed the galvanized rigging ,and the thought of his making his own sails with no previous sail making experience,horrified them. Designing his own boat with no previous designing experience ? "Laughable !
Too cheap to sail any faster than a half tide rock The designer and builder were not even "famous; "what a joke!
Then he went out and repeatedly beat some of the fastest boats , boat for boat. They grumbled about his low rating ,but couldn't bring themselves to admit that someone of his low rank in their yacht snobbery pecking order could sail so fast.
So they reluctantly, gradually, raised his rating , and he kept beating them boat for boat.
He raced against their "childish snobbery", an easy victory.
He gave them what they deserved!
I once read an article about an Aussie who kept beating the racing yachts with his 1930s gaff ketch. They banned him from racing, officially, so he went out and sailed circles around then anyway.
______________________________________________________________
Yes, I have noticed this and further, the more "high performance" the boat is (better suited to planing in heavy air) the less rounded boat-dimension curve there is. The curve at the turn of the bilge from the top sides to the bilge has a small radius. The bows are cardboard box straight. The longest curve comparable to boat-dimensions seems to be in the arch over the rear of the cabin at the front of the cockpit.
If you "more or less completely agree", regarding design by eye, why are you so critical when it's done by Brent Swain? Is it just the case that you have let him get right under your skin, and that now, no matter what he says, you will condemn him?
