sailaboutvic
Took a while didn’t it!
Yep , but he got there in the end .
Just leave the rest of the forum memebers to follow now . Or maybe the Mod will step in again .
Hi I am new to the forum and I’m currently doing research about what sort of boat to go blue water crusing with. I am a welder by trade so I’m leaning towards steel or alluminum as supposed to grp. I’m very interested in a Van de Stadt designs preferably alluminum boat but I worry about corrosion Issues as my price range means I’m looking at boats that are 15+ years old. Any advice would be greatly appreciated
Brent, If James follows your advice and makes a hole in the hull of somebody else's boat what do you recommend he does next?A hammer and centrepunch will let you know where the steel is too thin. If you cant drive the punch thru ,there is plenty of thickness.
Buy one of the cheapie online ultrasound steel thickness gauges, and learn how to to use it, to measure the thickness of any metal, anywhere on a hull, from outside.
Being a welder, you would be wise to rig an engine driven 100 amp alternator for welding. I have, and have built everything from anchor winches to windvanes to wood stoves , in my cockpit, at anchor.
If you were buying a wooden boat with a wooden mast, and the owner saidBrent, If James follows your advice and makes a hole in the hull of somebody else's boat what do you recommend he does next?
Thanks.
"Don't step there or you might go right thru, and don't lean on that mast ,or it may fall down, but the boat is sound and solid, "how would you react"? Would you buy the boat?
You could ask the seller how thick the plate is. If he says "plenty thick,' and believes it, then he would have no problem with your checking it out . If he doesn't believe it, and wont let you check it out, then he is lying, and thus you owe him zero consideration. You do owe some consideration to whoever he tries to con next. It could be a matter of life and death, possibly to children.
Brent , I not going to join in given you stick as many have here ,
BUT I have to say if I own a steel yacht and was selling it , no way would I let anyone use a punch to check out the thickness , you may just as well let them drill holes in the steel .
My years have been spend around GRP boats and in the same way I wouldn't let anyone remove a sea cock to check out the thickness of the hull which is much less damage then punching it with a punch or wacky it with a hammer , unless they willing to pay for the boat in advance.
He's actually bang ( ) on with the centre punch method, i do the same in the bilges, , though bit tricky on some one else's boat as it will likely damage the paint system. Any worries pre long passage then centre punch and a goog whack, anything more than a dimple then there's big trouble. Nothing like drilling a hole, it's a just good check in suspect areas. Maybe dull the point a little . It works.
Thanks.
I was hoping you might come up with a meaningful reply for a change - instead we get the usual evasiveness. Would you suggest putting a bolt through the hole made or would you need to weld a patch on the inside or the outside?If you were buying a wooden boat with a wooden mast, and the owner said
