mickshep
My new boat is built of 4mm steel below the waterline, after some 6 years laid up out of the water she is showing small areas of light surface rusting, Due to her location blasting with sand/grit is out of the question. On my previous boat the keel was of badly rusted iron, which I ground back to bright metal before giving about 8 coats of VC Tar applied directly to the bare metal. after 3 years there is no sign of further deterioration, I am thinking of treating my new boat in the same way, Any thoughts? ie, should I use a primer this time, Also I have noted that V.C Tar is now V.C Tar 2, Has it changed through improvement? or just more enviromentally friendly, in which case is it as good? Perehaps it has been superceded by a much better product. Thanks in advance. Mike
