stearing ram replacement on OD
simonfraser
13 Mar 2004
Outboards 4 mobo’s, unless you do a lot of miles
apologies for not knowing the type of OD, yet
it may have links which need to be removed from the inside / engine bay area
i will find out this weekend and will then have to make a decision as to what to do next
obviously the engine can be taken out, expensive.
but can access holes not be cut into the transon ?
perhaps use a remote camera as well so the mechanic can see ?
speculate please.
Hard to answer well with such little info but I think few would consider cutting through the transom a good idea.
Assuming you are talking about the power steering ram then I was able to change one by removing a few engine components to allow access.
