Steaming;- the results
Graham_Wright
30 Dec 2002
Gloucestershire
www.mastaclimba.com
Further to my request for advice on steaming teak, I have to report complete success.
Following the guidance offered, 20 minutes steaming with the wallpaper stripper in a four inch diameter (before,- after it was a bit oval!) plastic drainpipe, closed at the ends with foam pads (one left vented) and rapid action with the G-cramps made it easy. The addition of packing at the ends beyond the curve required compensated for the spring. I haven't calculated the radius but the chord was 850mm and the depth of chord 80. The material was 40 X 10mm.
Anyone contemplating something similar;- go for it, it's easy!
My maths. makes that a radius of 1170 mm.. More importantly, it's a neat DIY way to steam wood.
It would be interesting to know how much the bent timber would return to straight if left. Beware steaming thicker material.
I steamed (for hours) some 1.25" square teak 1.5 metres long to go under the mainsheet horse track on a curved aft deck. It fitted OK then a few weeks later the cracks started to appear in the deck as the teak tried to straighten the deck out.
Made a laminated replacement from 5mm thick teak strips. No need to steam them. The resulting beam looked nice and strengthened the deck instead of trying to destroy it
The bent timber is to be attached to a hatch garage fascia that blends in with the coaming (Countess 33, centre cockpit). I still have to decide how to fix it but the first attempt will be with double sided sticky tape. Before you capsize with laughter, out of curiosity I stuck a piece on the transom 5 years ago (not in the water) and I can't remove it. Although it isn't under tension so not representative, I will see how it performs for the hatch trim. As this is only decorative, unless someone dies as it springs off, it is not critical if it detaches.
