armchairsailor
Hello all. My first post in this forum I think... As a newbie to power boats I'm not really experienced in even starting them, so I thought someone might be able to give me some pilot notes, so to speak.
Tonight I decided to have a go at starting my old Sangster 18 project - it's a locally made 1979 vintage deep V speedboat with I/O 140hp mercruiser in the back. The thing has sat since i got it 2 1/2 years ago, so I'm not expecting it to fire up straight away at all! I was assured the thing was a runner when I got it, so it's time to see if it's true. My intention is to find out if the engine can actually run, and if so, then fog it up so I can remove it to rebuild the rotten transom, so this is the first step in saving it from a landfill. It would be nice if this wasn't a "do not pass go" project.
Batteries were sufficiently charged to light the navs, power the leg, run the blower and all that when the key is switched to the first notch. I turn the key to start and get the starter solenoid clicking but that's it. The ammeter shows nothing - even when hooked up to my diesel pickup, with its double battery setup.
I suspect the batteries are just completely pooched, given that it's been dormant for at least 3 years with no attention, but all the other electrics work, and it was being boosted by the truck, so I expected the ammeter to show something. I'll try and get a voltmeter tomorrow to check them, but could it be something else? I previously replaced the ignition switch from a 3 terminal one to a 4 terminal (4th being for accessories) so may have cocked something up there, despite carefully swapping the wires; but then the starter did click...
I'd appreciate any advice you might be able to give.
Thanks!
Thanks!
