Starter motor
hardy
14 Apr 2003
chichester
I have a big GMC V8 turbo diesel lump in the back of my Falcon,due to a problem with failed seacocks it was under water for some time and failed.No suprise, had it removed and a rebuild put on, this has now failed.
Question, obviously this is a marinised truck engine the obvious place for the starter is under the engine,When marinised looking throught the companys lit.You have an option of the starter on the top.as it takes half a days work to remove the thing (engine in)anyone know if this can be done retro fit. just in case!!!
Regards
<hr width=100% size=1>KISMET HARDY
PGD
9 Jul 2001
Thames - non tidal
www.peter-davey.com
Hi, if you need any bits I have a nearly new engine I'm breaking 5.0GL, GMC, done 30 hrs only, block is shot most other bits available, all as new.
Let me know
Peter
<hr width=100% size=1>Complete the Consumer Survey <A target="_blank" HREF=http://www.mssa.org.uk>http://www.mssa.org.uk</A> Marine Service Standards Assistance
scottie
14 Nov 2001
scotland
Check that you have all the water out the bell housing as if you dont the flywheel will throw right int o the starter
