rudolph_hart
Can starter motors - or indeed any electric motors - develop a dead spot?
My Yanmar 3GM30F (600hrs only) usually starts without problem every time, but on a couple of occasions recently the solenoid has engaged but not turned the engine (hot or cold). Usually, a jump from one of the domestics gets it going.
Engine battery (Vetus sealed 75Ah) reads 12.6v and shows the 'Green Eye' of a healthy full charge, several days after last charge, so I'm happy it's not the problem. Also, I'm reasonably confident that it's not a bad terminal post or earth connection, as I've checked them all.
Can a motor's windings degrade/break to give a dead spot at a specific point of its rotation, which would not be noticeable when it's running (because it's momentum carries it past the spot), but if it is stopped at that point, starting is prevented by no (or insuffiecient) power? If so is it common?
