bedouin
You need to factor in the return path as well - but I assume that will be equally short.It’s a short run, maybe a metre from battery to switch to starter.
Calculations suggest that you could just about get away with 10mm2 (that is NOT a recommendation) so anything over that should be fine - 35mm2 certainly more than adequate and you could consider going down a size.
