DrGonzoMIA
Active Member
Hi all
Been having trouble with starter cranking too slow to fire engine. Thought it was an old, clapped starter so installed a new one but same problem so must be down to wiring. It's a 1979 Leyland 6/98 5.7l diesel. The wiring circuit confuses me a tad as I can't seem to locate a starter relay any where which I would like to test. Should it have a relay somewhere ? Or do some older systems not have one? Seems to be getting the correct t current at starter as tested with a multimeter. And I grounded the starter with a jump cable to don't think bad ground is the problem. Must be a relay, fuse or wire? Thanks in advance for any info.
