onesea
This is true but most of us do.You should never leave a furled sail under tension when not ready to use.
We have the same friends… Long term crew for us when they’re in the uk.We have a friend sailing a Westerly Oceanlord across the Pacific at the moment. He had new rigging only a few months ago. A routine rig inspection whilst on passage revealed broken strands on the bottom of one of the aft lowers. He went up the mast to parallel some dyneema with the damaged stay. Whilst up the mast he noticed a broken strand on the other aft lower! They are sailing very conservatively with no mainsail. Now, another strand has broken.
So whats the cause? Bad wire? Bad hydraulic swages? Too much tension? Not enough tension? The rig was set up by a rigger.
They have another 1500nm to go
We met them in Bonaire. Nice couple.We have the same friends… Long term crew for us when they’re in the uk.
Oops I never knew this mine is always pulled tight , so I should let it go slack when not sailing when its all rolled up.What do you think that leaving it under tension does to the sail?![]()
They are that!We met them in Bonaire. Nice couple.
I ease mine before furling because a tight furl will tend to hold the tension in the sail ( partly due to friction in the foils) & also put weight on the bearings each end when furling.Oops I never knew this mine is always pulled tight , so I should let it go slack when not sailing when its all rolled up.
i sail on a boat that has these on forestay and backstay.I'm saving my pennies for a Cyclops smart tune smarttune Archives - Cyclops Marine for the forestay so we can really understand what's happening as we sail, not just dock tune.
At the other end of the spectrum, I tune mine to keep the mast upi sail on a boat that has these on forestay and backstay.
they work pretty well.
it certainly makes it easier to repeat desired settings, but i think that learning what settings are better requires a lot of sailing.., unless you are sailing in a popular OD class where they are known.
The numbers can be displayed at the mast, and they are logged, but usually there is a lot going on, and other variables at play, so learning from them isn't straight forward.
Practice days where you really focus on it would be a big help, but we don't get around to that.
I can only think of one occasion where a boat's mast fell down and they still did well in the race....At the other end of the spectrum, I tune mine to keep the mast up![]()
Not a criticism of tuning for racing but more that I wouldn't know what to do.I can only think of one occasion where a boat's mast fell down and they still did well in the race....
That is a very low tension setting. Do the leaward wires go slack upwind in a blow.Not a criticism of tuning for racing but more that I wouldn't know what to do.
We just tune to ensure the mast has a tiny bit of pre-bend. Not easy on mast that is like a telegraph pole, although it is tapered. We adjust to keep it in column. It basically set with 11 to 15% of tension depending on which wires.
To be honest I'm on a very steep part of the learning curve with rig tune.Not a criticism of tuning for racing but more that I wouldn't know what to do.
No. I left the caps without the split pins in so I could tension them on a beat to weather, but they didn't slacken. I think the stiff hull helps. The hull is foam core composite. 6mm outer grp skin, 25mm airex core, 6mm inner skin. The construction is far stiffer than a comparable hull of 12mm solid glass.That is a very low tension setting. Do the leaward wires go slack upwind in a blow.
11% on my 8mm wires seems very slack, so on 12mm would be like the wife's washing line.No. I left the caps without the split pins in so I could tension them on a beat to weather, but they didn't slacken. I think the stiff hull helps. The hull is foam core composite. 6mm outer grp skin, 25mm airex core, 6mm inner skin. The construction is far stiffer than a comparable hull of 12mm solid glass.
The rigging feels bad tight when you lean on it. 1/2" wires
No way. The rig is bar tight. With a my very large adjustable spanner, I really struggle to put any more turns on the bottlescrew. It's almost impossible.11% on my 8mm wires seems very slack, so on 12mm would be like the wife's washing line.
I bet your knickers look good on it when going upwind?![]()
