A
Anonymous
Guest
John, this point about DSC alerts inhibiting the message is the most serious of all. If your hands are tied up with sheets, for example, you can't get to the set or the RAM mic. These things are not a problem with a full crew but for the typical husband and wife cruiser when one is having a sleep, it is a big issue. You might think that this is something that happens once in a blue moon but that's not so. It is an issue several times per passage, in my experience.
What happens is the radio goes ballistic, making a noise at a level equivalent to an intruder alarm and continues until you shut it up - no doubt it stops eventually? I don't know I have never put up with it that long. The MRCC that sent the DSC alert makes the transmission almost immediately so unless you are Twizzle or move with the speed of Superman you will miss the MRCC transmission. Very often that MRCC transmission is to tell you which channel to tune to get the further information - e.g. gale warnings, securitees, etc. so you are completely stuck as you have no idea which channel to tune to.
I suggest that the DSC alert should be inhibited during all received transmissions or at the very least set to a level below the transmission volume itself so that the user can always hear the transmission.
You'd think you would be OK by staying tuned to Ch16 - surely then you would hear the MRCC transmission? No. The DSC alert still comes out, disabling the MRCC's transmission.
This is dangerous and entirely wrong.
I understand that there are requirements laid down by the standards and I have not read the standards, but this is dangerous, indefensible and plain wrong. It should be changed without delay and firmware updates made available to existing users. One day this will come up in an accident inquiry - I just hope that nobody is killed or harmed as a result.
