bumblefish
Hi Donm, how did you cut off the mounting bracket?
Indeed, I've just heard from SH, the change was in 2011.Hi, I think that I have found the answer. The original CP180 had the recessed back and the later models have the rectangular protrusion...
Fitted a CP180 flush last year, did have to enlarge the screw holes in the panel slightly. I'd have preferred the CP180i but the stub antenna at the back stops easy/waterproof flush mounting. Had to make up a little bracket to hold the mushroom inside the console behind the unit, works perfectly despite being inside a GRP console.I've just been sent some fixing screws FOC by Standard Horizon. I note that they are M4 with threads on both ends and a hex section between, as shown in the image in Post #4.
Surely these will prevent the unit from mounting flush if the specified 4.5mm holes are not enlarged to accommodate the hex section?
When I did my SH300, I replaced the supplied bolts with standard bolts with a nut and washer, so didn't enlarge the holes. Never worked out the function of the hex section.
