MedMilo
The nylon roller over which my 12mm anchor chain pays out has high edges in order to stop the chain popping off the roller and getting wedged between the roller and the housing in which it is mounted. I had this made by a mate who has a precision engineering business as the OEM Fairline roller had very low sides resulting in the chain slipping off regularly! The issue is that the roller's high sides make the edges a little weak and over the last few summers one or two chunks have been taken out of the outside edge of the roller. My mate is suggesting that he makes the replacement from stainless steel which will obviously be much stronger than nylon. Is it okay to have stainless steel chain running over a stainless steel bow roller? I guess it'll be a little noisier but I'm not too fussed about that really. But will it cause undue friction / heat and ultimately extra wear on the chain etc?
