NormanS
In most leisure boats the snubber is primarily there to act as a spring, to reduce peak loads on the anchor and boat. With really light boats using using chain in shallow water (no catenary) it is essential equipment. The shock loads can pull the anchor out or spill your beer. It is a useful function in heavy boats too. It also silences the chain noise. I put the snubber on before setting the anchor. It is much nicer to the boat if you stop suddenly.
For the spring to work well the snubber has to be springy and that will mean it will be thin and will fail well below the holding limit of the anchor and chain, so in strong conditions something else is needed to stop the windlass being pulled out of the deck or to prevent the chain back-winding out. That is where a second heavier snubber can help, or a wrap of chain around a cleat or best of all, a nice tidy chain stopper.
The chain stopper is not the thing to hold your anchor to the bow tightly. A claw with tensioner for example would be ideal for that job.
I'm with you, except I would NEVER wrap a chain round a cleat. Repeat NEVER.
