Hurricane
imho and experience,
the scope should be long enough so that there is "alway's" at least several meters of chain on the seabed, in ANY sea condition,
if you don’t, and if the chain can 'lift' or move the stock, there is big risc that the anker doesn't hold.
this means indeed that in very strong wind, you need a lot of scope,
so if you don’t have enough scope in strong wind you need a very attentive watch-out !
and yes I know that a long scope is difficult or dangerous in case the wind turns direction,…
now having “always’s some length of chain on the seabed, means you always’s have some amount of catenary.
I can’t quantize this amount, but I am anyway a NON believer of a rubber snubber on my anker chain.
12mm chain and lots of scope gives me very good catenary in any wind condition.
And indeed, when you don’t have enough scope, and the chain is pulled tight,
AND the anker holds between rocks fe,
You will feel that the chain is pulling with peak loads on the boat,
But then again drop more chain or move the boat to somewhere else
+1 absolutely.
I don't think I could sleep at night knowing that the chain was pulling directly on the anchor.
It is so obvious to me.
All anchors work best if the pull is horizontally across the sea bed.
It doesn't matter if the argeument is that modern anchors still work when pulled at an angle.
They all work better if pulled horjzontally so why push the limits.
I like my sleep.
