dgadee
Stainless work hardens. Does it - if left for a time - lose that hardened property by itself? Or is it hardened for good?
I think neither.Stainless work hardens. Does it - if left for a time - lose that hardened property by itself? Or is it hardened for good?
Dunno, but Samurai swords wouldn't be up to much if they went soft in the cupboard.
How long have you got to wait on this job?
Not quite correct. Austenite is stable to room temperature so no need for controlled cooling. Quenching would be ok but this might harden any retained ferrite so I would just allow it to cool. Theoretical annealing temperature is 730C but a bit more would be best. Dull red heat.Austenitic steels, the type we use for marine stuff, cannot be hardened by heat treatment. They harden when subjected to mechanical deformation, ie bending, drilling etc. Once hard it stays that way until annealed by heat treatment. This requires temperatures of around 900- 1000 deg. C. and controlled cooling. Not a domestic DIY task.
Age-hardening is an industrial process. The word "age" really refers to lengthy periods of time, (hours), of appropriate alloys under controlled heat conditions. I'm not aware of any metal that, in reality, changes properties under normal conditions over long periods of time. Copper doesn't and neither do bits on your boat or car. ( external chemical or mechanical processes excluded! Google "precipitation hardening".I suppose my original question was because I was wondering that if metals hardened with age (does copper do this?) then there might be a reverse effect. Obviously not if annealing is necessary. But is there actually such a thing as age hardening?
I think you are mistaking the reason why the aluminium was hardened in the first place. Just because you witnessed that it was too hard to work does not prove that it had hardened through age. As mentioned before, 'age' hardening is a low temperature heat treatment process, also known as precipitation hardening.From direct experience Copper and soft aluminium harden with age. To the extent that to bend old copper tube requires it to be annealed. Ditto for solid copper cylinder head gaskets. Annealing those was always required before putting the cylinder head back on.
My old mate Jim - he was Eric Broadley's chassis man - made me a custom alloy tank for a F1 Kawasaki powered race bike. Almost freehand.
First thing he did, with a soft and smokey oxy acetylene flame, was anneal the two sheets of alluminium. They became very soft and easy to work.
Before the annealing process they were virtually unworkable in the way he needed to carry out the beating and shaping.
No TIG or Argon welding then, all done with oxy acetylene.
From that, it appears some metals DO change with age, including copper.
I remember doing this (ash tray, wouldn’t happen in schools these days). The annealing was done in acid IIRC.Many years ago at school I made a copper bowl in metalwork by beating it in a leather pad. Gradually it would work harden, requiring annealing to soften by annealing.
