DavidMcMullan
Which is better on the bolt threads to allow stainless bolts to be removable from a cast aluminium binnacle after a few years - Duralac or an anti-seize grease? Any better recommendations?
I've only had experience with Duralac, which is fairly filthy stuff but seems to work.
For a close fitting joint like a screw thread:Which is better on the bolt threads to allow stainless bolts to be removable from a cast aluminium binnacle after a few years - Duralac or an anti-seize grease? Any better recommendations?
Helicoils.
Well, not really.
To avoid galvanic action causing the aluminium to turn to white oxide powder the two disimilar metals need to be isolated from each other.
A helicoil is simply a stainless steel thread in the form of a coil that is inserted into a slightly oversize hole that is precut with a matching thread to the external size of the helicoil. When inserted correctly it is tight and makes a really strong fastening for OE parts that require high strength, or as an easy and reliable repair to a stripped thread.
Unless the helicoil is insulated from the aluminium, if moisture is present the galvanic action will be likely to occur.
Duralac will work, I have no experience of Tef-Gel.
Caught without ANY suitable substance once, I used Vaseline. It was all I had.
I needed to tale the end cap off the boom where I had used it 3 years later and no found no galvanic action and all the fastners came undone OK.
You need to tell all the Navies of the world then - helicoils are used so that the bolt screws into a stainless thread which is the whole point of this discussion. I accept that corrosion will occur between the helicoil and the ally but the bolt contact is still steel/steel. Isn't that why helicoils exist?
