Stainless 316 or 303 for rubstrakes?
Tranona
10 Nov 2007
304 is fine for that application. I have those strips to protect against chafe from warps etc. No problems with corrosion or staining.
jfm
Jersey/Antibes
+1
For some reason those D section strips seem only to be availalbe in 304 but I too have found them to be fine and not stain or rust
Pennpromo
22 Jul 2009
Poole, England
is it 304 because it bends more easier than 316?
Moonraker, there's no real difference in the strength of 316 compared to 304, its all to do with the amount of chromium, nickel and molymbdeum, (never could spell it). 316 obviously has better corrosion resistance properties as these elements are in higher concentrations, I could look them up if you are particular!
So I guess that they are 304 to be cheap and cheerful and maybe to cross into other markets that are not so corrosion heavy. Generally if they are subject to movement across the face that keeps them clean such as in a rub rail. Otherwise always go 316 or 316L.
moonraker 36
20 Aug 2009
just pointing out 304 bends easier(acorrding to a freind of mine who makes stainless steel sculptures)than 316.
i no 316 is a better grade.
never said 304 was a better steel,just that it may bend to the contours of a boat easier.
