JimC
In my experience, most problems of this type are caused by the attachment point on the mast being too low. I have a similar setup to you (I use blocks though) and on the advice of the manufacturer I fitted the mast blocks about 1.5m above my spreaders. Fitting them at the spreader root would give exaclty the issues you describe apparatently as theres too much of a forward component in the pull...
Would that help?
I'm sure you're right: the higher the attachment on the mast the greater the vertical component in the ropes' tension. Mine are attached about 3/4 of a metre above the spreaders and probably would be better higher up.
