knuterikt
Details hereWhat is under the stainless steel cover? How does it work?
http://www.saltyjohn.com/cableport_boat_product.htm
If you took a really big green one, how is that going to keep out water ingress? From the illustrations each cable is not sealed but relies on a small dorade to help stop water from following the cable below.
GlatGland - totally sealed yet easily removed.
Binder connector. Big rubber boot. Cable and boot bent over and held in place with cable ties. Plenty of vaseline when assembling. 14 years no leaks no problem.
Hi Angus....
although not the prettiest solution on the table....... it certainly looks and sounds as if it could cure my problem.
The biggest downside for me is that I don't have the length of cable to do the loop required. B****y electricians or whoever wire up boats
invariably don't leave a loop or two or enough spare somewhere to do a revision to the wiring.
A common problem I find in most boats where add-ons and remaking ends are done.
Seems to me that either totally waterproof plugs and sockets on deck or a tall swan neck fitting kept away from ropes and lines would be better.
I had a gland for each cable on my old boat and every time I took off the mast I had to disconnect each cable below and pull out the cable from the gland.... a real pain!
Google doesn't recognise.... any more info?
FlatGland;-can't trip over it like a swan neck.
