TSB240
One of my last jobs on my to do list before launching was to check out the connections for my tiller pilot.
I usually find that the pin connections in the Bulgin multipole sockets last a year or two before giving any problems.
However this time round the socket connection was fine and as good as new the pin connector also looked the same.
However I just thought I would check out the original fitting on the lead to the motor.
The connection pins looked pristine from the outside but were virtually corroded away on the inside where the cables are attached
The screw connector pillars crumbled as soon as I put any tension on the wires and the few strands of wire that were left parted.
The power cables needed cutting back by over 2 inches before fresh copper strands could be made into a new connector.
I am happy that I found this before a serious fault happened on a long passage.
Hope this is of use to anybody that might be getting intermittent faults like unxeplained power off and/or switching to stand by!
Raymarine ST 1000
I suspect that with the rain we had last year that water has run down the cable into the connector and has gently fizzed away the connectors so I have fitted a heat shrink sleeve to over the cable entry into the plug as an additional protector.
Steve
Raymarine ST 1000
Steve
