Birdseye
Taken me ages to run this to ground so for the benefit of anyone who finds the same issue, there are two alignment settings for this instrument not just one
Basically the ST60 display receives direction signals from the masthead unit and puts them into the Seatalk bus. The analogue needle on the display has its own alignment settings - something that has to be done with the masthead unit disconnected and before adjusting the masthead unit itself. The alignment is then done every 30 degrees round the dial and saved.
Only then do you do the alignment necessary for the masthead transducer to correct any offset it might have. Methods for both settings are available from Raymarine.
In my case the display needle was all over the place and not knowing that it was aligned seperately, I simply used the basic alignment mentioned in the owners handbook and which is for the transducer. The result was that one wind direction was shown on the dial whilst another wind direction went to the plotter and the pilot. Confusion all round.
