ST 2000 Autoplilot steering by waypoint
Badger
17 Jan 2002
South East
Is there any reason that this pilot should not be able to steer by GPS waypoint from a standard horizon plotter and NMEA connection and viewed on a ST60 Graphic display ? Thanks in advance.
Provided that the plotter is outputting a sentence containing cross track error then it should work OK AFAIK.
A check would be to see if the Graphic was showing XTE.
As long as you are sending waypoint and cross track error to your ST2000 with either NMEA 0180 or 0183, you should be able to use the track mode by pressing +10 and -10 together.
From the operating manual -
If your navigator only provides cross track error information, you
must acquire the track manually:
1. Steer the boat to within 0.1 nm of track.
2. Bring the heading to within 5° of the bearing to the next waypoint.
3. Press AUTO.
4. Press -10 and +10 together to enter Track mode:
• the autopilot will start tracking to the waypoint
• the display will alternate between cross track error and the
locked pilot heading
You need to have your GPS sending APA, APB, WPL, and XTE at the least.
