beneteau_305_553
Brendan
One keel bolt had a zinc plated plate approx 70 mm square and 5 mm thick with,a nut, M8 I think, welded on edge to it. I think this is standard on Beneteaus. I didn't have large enough spade terminals to fit this so I twisted a loop in the cable and soldered it together. This cable was then bolted through this eye with a stainless steel bolt and large flat washers both sides.
The annodes have corroded but the keel hasn't.
I used more 6 mm2 cable terminated as above to link from the keel terminal to the bolt that fixed the annodes through the hull. I used long bolts through the hull so that the first nut held the annode to the hull and then the terminal was removable without loosening the annode.
The earth terminal on the atu was also taken to the same point.
I did get interference from the hand held vhf when on charge and also from the nicad charger I used for torch batteries etc and also from the 12 v dc to 220 v ac inverter that I used for powering the lap top. All these chargers seem to create interference so I turn them off when trying to transmit long distances.
Hope this helps
Richard
<hr width=100% size=1>Richard
Hope this helps
Richard
