Fr J Hackett
Sorry to be a bore on the subject but is it really nessesary to use 2" copper strip to attatch the ATU to the boats counterpoise. I am using a dynaplate because the boat is GRP and has an encapsulated keel ie no keel bolts. I am assuming that people are advising using a copper strip because it increases the surface area of the ground plate and connection, which seems logical if you are constructing the ground plane within the boat. I ask the question because it is proving difficult to locate a copper strip, all those I have located are only 0.005mm thick and expensive, the alternatives seem to be perhaps to cut up an old hot water cylinder, open and flatten a large pipe, use copper braid or simply connect with good quality wire. Whats the definitive answer apart from trying each in turn.
