Which small engine do you think that they don't make one for? On the list of manufacturers most of the common engines seem to be covered. I have been very tempted by such a device - even if access was limited and it meant me having to remove the starter motor and replace it with the spring one. As I can't start my engine by hand, it seems one possible solution to an otherwise challenging situation.Do you really think so? Quite apart from the fact that they don't seem to make versions for most small boat engines, it has to be bolted on in place of the starter motor, and in most small boats there wouldn't be enough space to swing the handle to wind up the spring.
I'm very impressed that it will start an engine that doesn't have a fuel tank. What do they mean by that?
What a great idea!! Full marks to the designer!
Am I being thick here? If you fit one of these do you always have to hand start, or does it work as a conventional stater as well? The website doesn't make it clear.
Or do you leave it in a box, and only swap it when the battery is dead? Not sure I'd fancy doing that at sea.
I believe Caterpillar bulldozers also had them in the 50s but it took hours to wind them up enough and once running they were left on for ages.Nothing new. Seem to remember them as options on Fordson tractors going back to the 1950s.
Useful for installations such as generators and irrigation pumps etc which are used occasionally and in places where a battery supply would be difficult.
But they have listed Kubota (which is the base engine for several 'popular' marine engines.Click on a few of the popular leisure engine makes, and see which engines they offer starters for. Look at Yanmar, for example, or Volvo Penta. And as I said, there's not enough room in most small boats to swing the handle, even if you could be bothered to unbolt and remove your starter motor and bolt on the springstarter. Wouldn't it just be much cheaper and easier to have a more robust battery arrangement, or even a spare battery?
A lot of engines have /had an option to have 2 starter bell housing which makes this a viable proposition dependent on cost and may even be a requirement if used in a SOLAS installation.
Main memory of seeing one in action is its a hell of bang when it goes off.
Fuel tank ref may be about engines with additional starting fuel
A bit like mechanics tool box always included spark plug cleaning brush
Why not fix the problem that is causing the flat battery? Might be a cheaper option.![]()
