Spray greace ?
Be careful of Silicon and graphite based lube for a boat
[/ QUOTE ] Silicon<u>e</u> grease is jolly good in small amounts on electrical connections.
Whats the objection to graphite. That it dries out and leaves an impacted mass of graphite or just that it leaves black marks every where. (garages use it for steering wheels, gear levers etc.)
does it have to be a spray? GT85 is the spray of choice for a lot of bike mechanics, bit more dear than WD40. has teflon in it I think.
A nice old bike mechanic once told me to use vaseline on bike gear and brake cables, he said because some additives can attack the steel but that doesn't quite add up to me. anyway, I've stuck to since and never had issues. If you can get it in there you'de be better of with a solid grease which won't dry up.
Wurth 'HHS2000' is a synthetic spray lube, it sprays on very thin for penetration, then the solvent evaporates leaving the grease behind. It is prefect for any slow-moving gears, cables, hinges etc, it is salt water resistant. I always keep a can on the boat, not cheap, but well worth the cost.
Peter
Peter
Seconded!!
I could only find it direct from Hurth last year, but there are now one, (or a few??), ebay sellers. About £15 per 500ml inc postage
I got my latest on ebay as I no longer have a Wurth account. They also do a good teflon dry-lube spray which is good on sail tracks/slides and hatch runners etc.
Peter
