extravert
It seems there are two common ways to hold in clevis pins, using split pins or using split rings (the ones where one of the ends of the wire bends through a right angle and points into the centre of the ring).
My understanding is that splin pins should only be used once, but split rings can be re-used. Are split rings just as safe and strong as split pins? Should they be reused in really critical situations, ie where the structure of the boat is dependant on the clevis pin staying in place?
<hr width=100% size=1>Adventures of the <A target="_blank" HREF=http://www.xrayted.fsnet.co.uk>Teddy Bear Boat</A>
