mullet
I have noticed that my Origo sometimes kicks out a certain amount of CO - significant enough quantities to potentially be bad for the health, though not for long enough to set off the carbon monoxide alarm (it has an LCD monitor showing the ambient CO levels, this is separate to sounding the alarm for dangerous levels). We are talking often >50ppm, on a recent cruise we saw >150ppm, albeit only once and when using both burners simultaneously.
I keep the underside of kettle and pans scrupulously clean so I don't think the CO is due to sooty deposit burning off them unless it accumulates soon after starting to cook (the flame can be very slightly yellow and does create soot); and I allow the burners to warm for a minute or two before putting a pan on them. The only correlation I have noticed is between the burner pots being almost empty and clean burning (ie no CO shortly before they run out of fuel). Pots are filled per their instructions.
Does the brains trust have any suggestions - is this just a feature of this style of stove? Something about the fuel I have been using? Sign that the burner pots are past it or need a hot burn to decarbonise? Any suggestions/insights gratefully received.
