Spiral spring.
Graham_Wright
30 Dec 2002
Gloucestershire
www.mastaclimba.com
I have made hundreds of helical springs in hard drawn phosphor bronze wire winding them in a lathe on a mandrel.
I now need a spiral spring (like a clock escapement spring) that I can then extend into a cone shape.
I've tried winding as before but between cheeks to cause each turn to wind on top of its predecessor but without success. I've also tried to form one by hand working along the length progressively slightly straightening each turn. Close but not close enough.
Any suggestions please? The wire is 2mm diameter.
Would it work better with a 'flat' wire as opposed to round ?
Why did the winding between cheeks then pulling the centre out not work?
Www.solocoastalsailing.co.uk
Why not place 2 No 10mm discs on a shaft, One disc with a thin 2mm shoulder to keep the 2 mm gap. The shaft made from a bolt. The 2 discs held by a nut wound up tight. . A longitudinal slotted hole in the shaft & shoulder to start off the wire. The head of the bolt held in a 3 jaw chuck. The other end in the tailstock revolving centre.
Now the problem is getting the wire to fit tight to the coils. Fit a piece of steel in the toolpost like a lathe cutter but with 2 small bolts in the side of it held parallel to the lathe centre. The wire passes between the bolts & is kinked, thus bending it . That makes it pre bent & want to curl tightly into the gap between the 2 plates or discs. It also adds friction to keep it tight. When you reach the full diam of the discs stop. Then undo the nut & separate the discs. The slotted hole allows one to draw the wire along the bolt & cut the wire from the slotted hole with a dremel so it can be released from the bolt.
Now one can pull the middle out & form the cone. Obviously it will not be totally small in the middle but you have not said what it is for
I do not know enough about heat treating to know if it should be treated at this stage or not. Others may comment. Also the type of wire will have a bearing on the work. But i believe that as the OP has done spring winding he will have some idea of wire type best suited to the task.
