SP106 Eposy Resin
jneale
16 Feb 2010
Fareham
Not having much luck with this when coating bare plywood. I've done all it says in the fact sheet re preparation etc, but the surface separates into meniscus globules after application. I Have tried warming the mix etc, to give it more fluidity, but it still too thick to fully absorb into the wood. Big problem when it goes wrong as its a bugger to sand it flat again. I was thinking of thinning it further with acetone, but anyone got any better ideas.
prv
29 Nov 2009
Southampton
Don't have anything to add re causes, except to say that I've never had this problem with West epoxy, but I have read a couple of well-informed articles which advise against thinning epoxy with solvents.
macd
25 Jan 2004
Bricks & mortar: Italy. Boat: Aegean
For making epoxy resin less viscous, see this:
www.epoxyworks.com/14/pdf/ThinningEpoxy.pdf
From the sound of it, though, your beading problem is some sort of contamination.
Problems applying second coats are usually due to 'amine blush', a waxy deposit to which some epoxies (notably West) are prone when cured in high humidity. This is usually scrubbed off with water.
Boathook
5 Oct 2001
Surrey & boat in Dorset.
Never had this problem myself but as others have said it seems like contamination. This would also possibly apply if the wood has been treated with some anti-rot stuff, especially if it was oil based.
DownWest
25 Dec 2007
S.W. France
One of our OZ posters recommends meths for thinning. Personally I use Resoltech Re1010 for coating. Very easy and sets smooth, no amin blush.
Did you warm the wood first? Helps the flow. But it does sound like contamination.
A
Wakatere
10 Aug 2005
Solent
I think SP specify 320 for coating rather than 106.
I agree with others about surface contamination, though.
Good luck
Charles
oldsaltoz
4 Jul 2001
Australia, East coast.
Between now and warmer weather I would be sanding all the epoxy off to remove the contamination.
The epoxy you have already applied will not have penetrated due to the contaminant so must be removed or you will be wasting materials and time.
When you finished sanding, wipe down with white cotton rags and Acetone.
One of the products you can use to thin epoxy resin is denatures Alcohol, that's Methylated Spirits to most of us.
But most fast evaporating products will work but will cost a lot more.
The exposed end grain on the edges will take 4 or 5 times as much as the surface veneer, so keep wetting the edges till that will take no more. Apply wet on tacky to avoid sanding between coats.
Always clean the epoxy coating that has cured 'before' sanding, or you will just be spreading and contamination.
Good luck.:)
