MagicIsland
Can you step the Mast on a Southerly 105 ? If so does anyone know how long it takes and how easy it is and then to raise it and get the rigging right ?
It might help if you explain exactly what you mean by "stepping the mast", as it doesn't seem to match my understanding of the term.
To me, stepping a mast simply means putting it up, whether that be by crane in a big boat, by hand in a small one, or using a tabernacle and gin pole in a medium-sized one. Obviously the answer to the question "can you put up the mast on a Southerly 105" is yes
Sorry, was asking if it was possible to take the mast down and raise it again on your own without the need for a crane using a tabernacle and pole ?
thks
Our 105 has the old tabernacle mast. Technically, it should be possible to lower and raise without a crane, but I haven't quite worked out what would be the best way to do it. Maybe borrow a halyard from a neighbouring boat?
Cardo, what year is your southerly 105 , do you know if the changed the desin later ?
