yerffoeg
Thanks everyone for some great advice. Will definitely consider going to Cherbourg instead of Braye.
If the prevailing SW'ly wind is blowing (at F3+), I would have thought Brighton to Cherbourg in a boat doing 5 kts could be a tiring beat. 90nm could become 125 with the wind on the nose which, at 5 kts, is over 24 hours!
For some reason, we were always lucky with this leg, sailing in late July/early August. I wouldn't dream of setting off on a 90m beat, but the same weather could make it hard to get from Brighton to the Solent in a small boat. On one memorable occasion we set out from Brighton in a NE6 and by the time we were halfway across we were motoring in a calm while the Royal Sovereign was reporting F7 in the previous hour.
I think the OP's best bet is not to think to hard about it all at this stage and then just see what the weather throws at him a couple of days in advance.
As has been noted, Cherbourg is far easier for a first x-channel. Timing the race for Alderny is a significant challenge, especially in a smaller boat. Also, there is far more to do and see in C-bourg than in Alderny.
Besides that, C-bourg can be entered at any state of tide and in any weather. You don't really have to time your passage at all -- just go out whichever end of the Solent the tide is carrying you at the time of your departure.
For the tidal vectors, I recommend acquiring Neptune Planner+ rather than doing it by hand. Far more accurate and far less tedious, which means you can rerun the numbers frequently as you progress. Set your waypoint a mile or two uptide from your destination.
Then if you really want to see Alderny, the passage to there from C-bourg is far simpler than from across the Channel. But instead of Alderny, consider St. Peter Port, which is much more interesting, and you can buy cheap fuel and booze, too.
Cherbourg to Alderney isn't without it's own problems. If you aim to get to Cap de la Hague just before the tide turns South, you're going to have a foul tide along the French coast.
I go that way too, but fine details would of course depend on the weather but I would be looking for a favorable slant once I was past Ramsgate. Somehow even Boulogne feels more like being on holiday.Not that bad if you stay inshore & catch the back eddy. But in rough weather do not try to cut the corner too tight
I am going to CI's from Bradwell around 3-7 June. I have to be there for wife flying in on 18 June
My route - which I always do- is Boulogne, Dieppe, Le Havre, cherbourg, St PP
All harbours easy to get in 24 hours. no navigation problems apart from corners of Cherbourg peninsular. Cheaper marina fees I am told -as well & going foreign gives it that holiday feeling. Kids would probably like that if you have them
Cherbourg marina give 20% discount to RYA members so if you get holed up there waiting for a weather window it is fairly cheap & you can go on trips inland if you want
The back eddy isn't that reliable until you get quite close to Cap de la Hague and you will be in the wind shadow of the peninsular in the prevailing SW wind if you're close in. He's got a 27' Sabre, I have a 26' Nicholson so we're pretty close in performance and 5-6 knots isn't a lot with the tides around there.
Hello,
I am planning to sail to the Channel Islands for the first time in July. My Sabre 27 averages about 5 knots (probably a bit optimistic). I will probably port hop around the English Coast from the Blackwater, make the crossing, and then port hop the French Coast on the way back.
I was wondering about the best departure point from the South Coast: Portland? Yarmouth? Lulworth Cove? Any other suggestions?
Thanks.
Why is everyone saying this is difficult?
Braye can be entered at any state of tide. From the South Coast you are going to go through one full tidal cycle so little effect and so you can simply sail at best speed, with a waypoint to be uptide in the last hour. The ebb tide is vicious and will suck you South so fast that you should ensure your VMG is still OK - I have on occasions steered 25o off the VMG.
IMHO, Braye is far more pleasant that Cherbourg - walk up the hill to St. Anne and bizarrely you can have a great curry at Grays Nellie.
