Sourcing Navigation Light Bulbs
max_power
10 Jan 2003
I need to buy 4 of these bulbs. They seem very expensive in chandlers.
Could they be cheaper somewhere else , say auto shops etc ?
Many Thanks
Forbsie
9 Mar 2002
Try <A target="_blank" HREF=http://www.maplin.co.uk>Maplin Electronics</A>. 5w bulbs for £0.49.
<hr width=100% size=1><A target="_blank" HREF=http://www.arweb.co.uk/argallery/forbsie?&page=1>My Project</A>
MartinGPerry
28 Dec 2001
ASAP Supplies are a very good supplier of electrical and mechanical goods for marine & auto use
Their prices are often about 50% of what chandlers charge - they have most Nav light bulbs styles on their web site
http://www.asap-supplies.com/
Martin
Jools_of_Top_Cat
16 Dec 2002
have you the same as me, the aqua 45 range with dimples rather than points on the festoons. No one else does them, but you can break the old ones off the dudd bulb and slip them over the pointy kind.
Hope this helps if this is the case.
<hr width=100% size=1><font color=blue> Julian </font color=blue>
<A target="_blank" HREF=http://www.topcatsail.co.uk>Homepage</A>
jmp
6 Feb 2003
Notts--England
Just got some from vintage car restorer 50p each , but pointy instead of concave .
Another trick to avoid being ripped is to drill the dimples out of the contacts and use the more easily obtained pointy ended (presumably festoon bulbs).
Good luck,
Michael.
<hr width=100% size=1>jmp
max_power
10 Jan 2003
Thanks everyone !
Thanks to your help I have found a source where they cost one pound forty pence each as opposed to six pounds fifty each in a chandler.
The only difference is that they are 21w instead of 25w - no big deal.
Julian
Thanks for the tips
Regards
Max
VicS
13 Jul 2002
What you have found sounds like automotive bulbs. The problem you may find is the design of the filaments. Nav light bulbs have the filaments orientated axially to comply with the the requirement to cut off the arc of visibility cleanly at the correct angle. They are also on a special support which does not obsure the filament.
You may not consider this matters though.
max_power
10 Jan 2003
Thanks Vic - Did not know this but makes good sense.
I have an old bulb which has an anchor motif stamped on it probably for the reasons you state.
I still have an original bulb and will compare them with the new ones .
Regards
