RichardS
N/A
Whilst I'm on the hard I've taken the opportunity today to drop the starboard rudder. The port lower self-aligning bearing seized last Summer and we had to fix it in the slings before we could continue our cruise to northwards so I'm now making sure that the starboard one is OK.
The "good" news is that the grease on the rudder stock/self-aligning bearings has dried up or washed away completely so the stock would soon have imitated its port cousin. However, it wasn't completely seized so SWMBO and I were able to drop it. I will grease it tomorrow.
However, whilst I have got the nylon ( I guess it's nylon?) bush/spacer out I have taken a picture:
As you can see, this one is in good condition but the identical one on the port rudder has almost split where the bolt goes through it. At the moment I have a couple of cable ties on it for security but I really need to replace it.
The size of the bush is OD 70mm, ID 40mm, Thickness 20mm. I have measured the rudder stock and that appears to be 39mm and hence the slightly larger spacer ID.
Is 39mm some kind of "standard" size for stainless steel rudder stocks? Just as a reality check that I've got my measurements correct.
Does anyone know where I can buy this kind of bush/spacer? Is it nylon? Even if it were solid I could drill the bolt holes myself which might make finding it a little easier.
Many thanks
Richard
Many thanks
Richard
