5teve
Hi Guys
A bit different to the usual engine room noise question.. as the engine room has foam above it so internally the noise isnt too bad.
The issue is that the builder who is local made the engine vents face inwards where the saloon doors are. Great idea to stop any salt water ingress into the engine room in the crappy seas we get.. but not so good for holding a conversation when underway if you are sat on the deck..
Most of the noise comes up through the 'ducts' which to be fair are pretty big (probably 300x300 cross section at the top and 1000x500 at the bottom) so I am looking to tame the noise. I have been looking at the typical pyramid type foam and looking at sticking that inside the ducts to absorb the noise and also add a plate behind the louvered panel (maybe stood off the vent by 50-100mm also with this foam on)
I dont really want to spend the money on the foam without some confidence its going to mute it.. most of the stuff I read insinuates that it absorbs certain sounds - but i'd be interested to hear your thoughts on what may work..
