Latestarter1
Thanks guys for your most helpful replies, I knew Paul's would be a bit more in depth one lol I know about the poor exhaust risers that were fitted, not sure if mine are or not, however they are SS ones and if I am right in thinking it was the cast ones that gave the problems, the water inlet pipe does seem to sit right on the top of the riser which could let water back towards the turbo once the engine is initially switched off.
I don't have exhaust temp gauges but I do have over heat exhaust alarms, they have never sounded.
I do know about the inter coolers blocking and the tel tale sign of burnt paint, I am happy to report that neither of mine have burnt paint and still look like brand newbut I didn't know that the raw water was split to divide between the inter cooler and the heat exchangers.
Where can I get a turbo boost gauge from and any ideas of the pressure they should be running at? Can you they be tested off load or do they need to be on load
The one engine definitely makes 2800 with ease, the other has only achieved 2400,this happened in the boats first year after that engine had a new prop fitted, Caterpillar did tests on both engines and could not find any reason for it to do it, so it was left as it was, it was suspected that the prop was a slightly different pitch to the other one, I do have the original prop so I might fit it next time it's out of the water, but it is the whole of the transom that gets covered in soot so it's both engines that cause it.
mrs oaf just commented that after our first trips out she remembers me saying how pleased I was that the transome stayed clean, with my last boat P35 the transome used to soot up, (TAMD41B from memory) and I never really pushed that along, so am I cruising to slow
I do think that as others have said, they need a bloody good *******ing
PS Paul the boat is pretty much always fully loaded with gear and tanks and now she only makes about 27 knots flat out, when I bought the boat on trial it did make 30 but only just
Question answered!
The engine only making 2,400 rpm is heavily overloaded and is making your soot. Luckily you mentioned this before giving motor the beans. Failing to make WOT by such a large margin is placing a huge load on the engine. Guys from Finning needed shooting, the CAT ET diagnostic tool would have been showing 100% engine load before motor had even spooled up to 2,400 rpm.........Complete clowns, together with the people who made such a hash of the prop, all as much use as a one legged man at ass kicking party.
Get your original prop spec for your vessel which would have originally been approved by Finning and insist the replacement prop has pitch graunched back to this spec.
Moving on as I said earlier EGT gauges are common in the U.S where boaters are very much performance aware. Nothing to do with your exhaust temperature alarms.
Have posted before but ISSPRO Turbocators are a neat piece of kit.
