fredrussell
I installed one of these tiller pilots a month back now and would appreciate some input from any other users out there. My main question regards rudder hard-over time. The manual is a little bit vague (at least to me) so can you tell me what you have yours set to? If I set mine to anything below 5 seconds the ram moves very slowly when changing course. Set it upwards of 5 seconds and ram moves as I would expect it to. Am I right to say that what Raymarine mean by ‘hard over time’ is the time it takes ram to move tiller from one extreme to the other? I would have thought that with my hard over time set to, say, 4 seconds, the ram would move faster than when hard over time is set to 10 seconds. Is that right? If it matters, my boat is a Parker 31 - very responsive and light on the tiller. 3 tonnes displacement, though nearer to four with all the crap I’ve put on her.
Incidentally, I do have a rudder position sensor but haven’t fitted it yet as I have a transom hung rudder so it’s going to take some work to install it.
Next question. When I select auto tack the boat swings round as it should but then the ram reaches the end of its travel (on bump stops) and eventually switches controller to standby, this despite me setting max rudder angle so ram shouldn’t be able to bottom/top out on bump stops. I should state here that tiller pilot is NOT connected to a wind transducer - does this mean I can’t use auto-tack feature? My previous TP (St2000) just auto tacked through 100 degrees - can I assume that the EV100 will not do this?
To be fair, this EV100 is way, WAY better than the ST2000 it replaces, but I do find myself wishing Garmin would make a tillerpilot! I’ve emailed Raymarine using their user support contact feature on website, but heard nowt back in the two weeks since doing so. I’ll see if I can find some sort of technical type’s phone number on website, but I’d appreciate hearing other user’s experiences before doing so. Cheers.
